advice needed
Old Nov 8, 2012 | 03:51 PM
dirtydan2727's Avatar
dirtydan2727
Default advice needed
First off id like to say thank you to all that reply wit comments n for your help..
Here's what I got for a problem got a 93 Dakota to get it started have to hold gas pedal to the floor..Once it starts u have to feather the gas pedal til it catchs n keeps at a ideal..If u give it gas from that point or go to put it in reverse or drive it stalls out..Here's where I need ur advice what could it be??? It's driving me nuts...
So far here's the list on things I'm done or changed..
Spark plugs
Wires
Distributer cap n rotar
Fuel filter
Fuel pump
Checked pressure
Whole new throttle body n all sensors on it
Old Nov 13, 2012 | 02:33 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a bad vacuum leak or bad EGR or bad fuel pressure (did you check it correctly with a fuel pressure gauge?).
Old Nov 13, 2012 | 10:01 AM
volaredon's Avatar
volaredon
sounds like just catching up on neglected maintenance based on what you've replaced so far...I would not feel a bit bad about replacing any of that stuff, if it had not been done in a couple years or more; I just hope you used decent quality stuff, not "the cheapest thing to fill the hole" but it sounds like its flooding out somehow;
