EGR Delete?
Old Nov 17, 2012 | 09:29 PM
keilkravec's Avatar
keilkravec
I ask becuase I have been having some nightmarish trouble resulting from either that or the O2 sensor I got, its been bogging down and losing power like a blown headgasket, and when i say bog, I mean it isnt even firing while going 70mph, but when I gave it more than 3/4 throttle it was all there. let alone having to get on and off the gas every quarter second to keep at speed and if I tried to hold steady gas it would stop firing and bog or I would literally watch my tach go insane and up and down from the engine going bat**** crazy and backfire worse than a popcorn machine, and that is not an exageration.
Put the original O2 back on and unplugged the vacum line to the intake off the EGR and plugged a bolt in the line, now it runs fine again minus a little more pinging than usual.
Old Dec 20, 2015 | 05:15 PM
Mmorris98's Avatar
Mmorris98
Originally Posted by ricekiller
my egr is deleted because the headers dont have the bung, and the diaphram in the valve was bad anyway. its a VERY simple procedure. but in my experience, EGR does not help fuel mileage. ive found it to do quite the opposite.
How do you delete your egr like step by step I'd like to do it do o can install new headers
Old Dec 21, 2015 | 09:07 AM
onemore94dak's Avatar
onemore94dak
If I wanted to do it I would remove the EGR, trace its outline on some sheet metal and cut/drill it out. Then replace the EGR with the sheet metal in between it and the mount.
