problem removing shocks
Old Sep 6, 2005 | 05:17 PM
speedreaderz's Avatar
speedreaderz
Default problem removing shocks
1996 dodge dakota
Trying to replace shocks . having problem with getting top bolt removed - when trying to remove spins rod in shock around.
tried clamping rod but does not hold . Anyone seen this before. Do i need a special tool to remove the bolt ?
Thanks
T
Old Sep 10, 2005 | 01:52 PM
pembroke dude's Avatar
pembroke dude
Default RE: problem removing shocks
You should use tourched and just cut them off it saves a hole lot of greaf.
Old Oct 2, 2005 | 06:14 PM
Kotakid's Avatar
Kotakid
Which shocks are you tryin to replace front or back? Im takin that you are replacin the front ones. Well to do that you have to get a wrench and a pair of pliers perferably vice grips so that you can lock it down. Just take the vice grips (or pliers) and clamp on the flat part on top of the shock and take the wrench and loosen the bolt while turnin the vice grips (or pliers) in the opposite direction. From the way my 94 looks it looks like you can just take vice grips and clamp down on it and then loosin it with a wrench until the grips hit the control arm and that will act as leverage. The also make a special tool to go over the top of the flat spot on the shocks makes it easier to handle but vice grips or pliers would do the samething. So i hope this helps ya, if it doesnt just let me know whats going on and ill help ya.
Old Nov 15, 2005 | 04:53 AM
undertaker420's Avatar
undertaker420
I just replaced my shocks on my 91 dakota. I used a Dremel and zipped the bolts off. It only took me about 45 mins to replace all 4 shocks.
