Dakota Overdrive issue
Old Nov 22, 2012 | 11:10 PM
tjbend's Avatar
tjbend
Default Dakota Overdrive issue
im having a problem with my truck not going into overdrive...1993 dodge dakota, 6 cyl..i just replaced the speed sensor and it did not make any difference...i also dont have cruise control...so if the speed sensor is new, what should i try next to get my overdrive to engage? i have also checked the fuse and it is good...please advise..thanks
Old Nov 23, 2012 | 10:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You may have bad wiring or a bad OD off switch. Get a mulitimeter and test each wire in the circuit.
I will move this to the 1st generation Dakota sub-forum.
