Engine swap
Old Dec 10, 2012 | 10:41 PM
Tn4x4mudder's Avatar
Tn4x4mudder
Default Engine swap
What all would you have to replace if any to swap a v6 for v8
Old Dec 11, 2012 | 12:08 AM
moparnut38's Avatar
moparnut38
pretty much just have to use the wiring harness from the v-8 and the computer
Old Dec 11, 2012 | 02:03 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For the Magnum motors it is easy, the V8 is a direct bolt on. All you need is a complete Magnum V8 and PCM and just need to add in 2 more injector wires to the engine harness. The V6 transmission will bolt up but wont last as long behind the V8. Dodge didn't put them behind the V8 for a reason.
Old Dec 11, 2012 | 06:52 PM
Tn4x4mudder
Well I got a bad year.cause the transmission that I have was a tester and the only put it in 1992 and 93 dakota and a few jc jeeps.i some teeth on my old one pulled it out of the mud bout never find a new one
Old Dec 12, 2012 | 01:04 AM
keilkravec's Avatar
keilkravec
It's a 42rh if you have the auto and v6, if its a stick then its the AX-15. It's not a tester year they used the ax15 till 96 and the 40 series RH till 95'.
Old Dec 12, 2012 | 01:31 AM
WRXCarl's Avatar
WRXCarl
Yea just grab a 318 with a trans too. It will be the 46RH. Have a transgo shift kit instaled as well as an aftermarket trans cooler.
Old Dec 12, 2012 | 10:12 PM
Tn4x4mudder
Thanks guys
