Engine runs pretty cold
Old Dec 28, 2012 | 02:15 PM
1993dd's Avatar
1993dd
I really appreciate all the feedback! Yes, I think it probably just reads a little lower on the gauge and I need to find the "normal" range for this truck. Thanks!
Old Dec 29, 2012 | 09:42 PM
93MissDakota's Avatar
93MissDakota
I got the same thing, ive replaced both sensors, 180 thermostat and new water pump, and it still just comes up a little and stays, which is fine, my thermostat is opening at 180 and everything stays cool, even in 100 degree summer driving. im cool with that!
Old Dec 30, 2012 | 05:34 PM
bran1har's Avatar
bran1har
I replaced the coolant temp sensor on my v6 and now it reads right in the middle. Truck still takes forever to warm up though.
Old Dec 31, 2012 | 07:54 AM
dodger8691's Avatar
dodger8691
I had the same problem with my 96 v8 It swould overheat going down the ocean so I replaced the t-stat and now the heat barley works and the needle don't really move either found out that my overhearing issue is the fan clutch this summer I'm gjnna revamp the entire cooling system
