88 4x4 Bushing Help!
Ok...I have an 88 Dakota with 23x,xxx miles. Among other things the suspension is shot and I am in the process of swapping everything out. The ball joints fell apart after I pressed them out. Tie rod ends were shot. Long story short it is getting some much needed TLC.
On to my problem. I am having an issue with the upper control arm bushings. I am using the Energy Suspension set fyi. I heated out one side but the inner sleeve appears to be part of the center bar. I am holding off on heating off the other side because the bushing is the only thing keeping the center bar aligned.
My questions are the sleeves replaceable or do I just press the bushing in over the original sleeve? For pressing in the bushing I am planning on pick up a 3 arm puller to attach to the lip on the control arm but I don't know where to find a sleeve the right size. Anybody have a better idea or know where I can pick up sleeves that would fit a bushing.
Thanks in advance
Thanks in advance
No, the inner sleeve will come off but may require some convincing.
It's been several years since I replaced my upper control arm bushings, but I think I ended up taking the control arms to a shop to get the pivot bolt [the thing the bushing fit over] removed and reinstalled. (I had bent a control arm attempting to remove the pivot bolt and didn't feel like screwing it up again)
