1994 dodge tranny problems
Old Jan 24, 2013 | 01:41 PM
raytapp's Avatar
raytapp
Default 1994 dodge tranny problems
i have a 1994 dodge dakota with an a500 v6 transmission and a 5.2l v8 motor and it takes off in 2nd gear instead of 1st what could be the problem?
Old Jan 24, 2013 | 02:02 PM
DakotaRT1993's Avatar
DakotaRT1993
Solenoid
Old Jan 24, 2013 | 02:10 PM
DakotaRT1993
that thread is about a 46RE but it is fairly similar to a RH, probably something sticking or blocked.
Old Jan 24, 2013 | 02:32 PM
raytapp's Avatar
raytapp
its not leaking any fluid could it be the speed control sensor?
Old Jan 24, 2013 | 03:29 PM
DakotaRT1993
The vehicle speed sensor should have nothing to do with it starting out in second gear. Does the truck shift normally in the other gears? If you shift into 1 on the gear indicator and drive what does it do?
Old Jan 24, 2013 | 04:39 PM
raytapp's Avatar
raytapp
it shifts normal in other gears and 1st gear on the gear indicator dosent move when i give it gas, and the transmission was just rebuilt before i bought it.
