1994 dakota charging issue
Old Jan 27, 2013 | 11:44 PM
bbizelli's Avatar
bbizelli
Default 1994 dakota charging issue
Hey guys im having some problems with my 94 3.9 5 speed dakota the amp gauge will drop down to 8 and then the check engine light will come on. I took the alt off and took it up to autozone and tested it and it came back good. If i rev the truck to 4 or 5 grand the gauge will shoot back up to normal. Would this be a voltage regulator problem? If so i know the regulator is built into the ECU so i would have to replace it or is there a way to wire an external regulator to it? Or is there any other components that would cause this? Any and all help is greatly appreciated thanks!
Old Jan 28, 2013 | 02:00 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The autozone quick test can be inaccurate sometimes, if the alternator is not completely dead. Lets just say it's dying but not completely dead yet.
90% of the time it passes the autoparts stores tests and it still can be bad. I would suggest to buy one and test it out. But first you may want to check your wiring, make sure you have contiuity on all wires and their outputs.
