help with lights
Old Sep 12, 2005 | 10:27 PM
mikerickbob's Avatar
mikerickbob
Default help with lights
ok so i was driving my 1990 dodge dokata and all the sudden the signal lights stopped working. i pulled over and found that the brake lights were also not working. i found a blown fuse replaced it and starded it up and it blew. i replaced it again and the brake lights work but not the signal lights. i checked the bulbs and they are all fine. any ideas thanks
Old Sep 17, 2005 | 03:58 PM
jrmayer01's Avatar
jrmayer01
Default RE: help with lights
hey i am having a similar problem here, but my fuses are all good but the brake lights don't come on when i depress the brake pedal. dodge recommended replacing the circuit bulb strip that inserts into the lamp, but there is no refund on that if it doesnt work, which it didnt for me. if you find out what the issue was for yours, fill me in and i will do the same as well...thanks
Old Oct 2, 2005 | 06:25 PM
Kotakid's Avatar
Kotakid
Ok to try and help i need more info does the signal actually turn on and not blink or does it just complete not turn on or blink.
Old Dec 12, 2005 | 06:18 AM
cobra55's Avatar
cobra55
my turning signal's do the same thing, my problem is the multiswitch, brake lights work fine
