'93 doesn't have brake/turn lights or dome/radio power
I have checked all the fuses and everything looks good. I removed the t-tapped trail harness and the wires are still intact. I have a brake signal coming out of the switch and going to the turn signal stalk. When I turn on the blinkers or hazards, neither flasher clicks.
As for the radio and domoe not working the only thing I have checked are the fuses and the constant wire behind the radio which is sitting at ground.
Any idea on the path the wiring takes from start to finish?
Thanks.
Thanks.
i installed a aftermarket radio in my truck and also lost the radio and the dome light. the fuse they put in the back of my deck was too small, and i blew the fuse under the hood. it was a little 5 amp one. check that one. if not also check the fuse in the back of your radio. good luck
That's really strange .. I just encountered the same problem today. I was putting in a red light bulb for the "glove department" and next thing I know my cd player, dome light, key light, and everything connected to the door switches just stopped working. All fuses are good to go even the ones under the hood and behind the cd player. The 4 amp fuse in the fuse panel is not receiving any power but it isn't broken. Thats all I could find with mine. Sorry that I couldn't help out with solving the problem more.
