The parking brake foot pedal broke where it pivots. I've taken the old pedal out, disconnected the cable & electrical wire indicating the brake is on. Got a new pedal from a salvage yard and can not pull the cable out enough to get it to slide into it's hanger/holder/bracket. Do I have to take some part of the cable apart along the frame under the truck? If so, how much of a PITA will it be to reconnect that after I get things connected under the dash? Whats the right way to start and finish this job so it'll pass inspection? Thank you in advance.
