Egr?
Old Mar 12, 2013 | 03:46 PM
mjm2198's Avatar
mjm2198
Exclamation Egr?
So I just had my 94 dakota 2wd v8 transmission rebuild in which before hand the dash codes were blank, when i got the truck back i noticed right away the ABS light was on for the first time and shortly after the check engine light goes on randomly and it has rough idle/acceleration at times, so i ran the code check again and got error code 32 which apparently is the EGR system, can anyone tell me what any of this could be or how i could troubleshoot it? thanks.
Old Mar 12, 2013 | 05:57 PM
JR318's Avatar
JR318
Check the wiring to the EGR or possible bad O2 sensor. The O2 sensor could have got damaged when the trans got fixed and it can also cause the EGR to work incorrectly. Make sure the EGR tube going to exhaust manifold is sealed good.
Old Mar 16, 2013 | 10:11 AM
ricekiller's Avatar
ricekiller
vacuum?
