Gauges all suck
Old Mar 25, 2013 | 12:45 AM
matteusclement's Avatar
matteusclement
Default Gauges all suck
What gives dodge? All my gauges are out to lunch.
My coolant gauge never goes past 1/3 even though I have hot air and hot fluids.
My fuel gauge might as well be drawn on with crayons with how inaccurate it is.
What can I do to get accurate readings for these two very important things?
Old Mar 25, 2013 | 11:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Coolant gauge might be just the normal location. If you have a lower temperature thermostat then stock which is 195 then it would read lower. If you want you can change the sensor which is $10 or so. Keep in mind the Magnum motors used 2 sensors 1 for the gauge and 1 for the PCM. Check the FAQ in this section for pictures of the locations.
The fuel gauge is probably a bad sending unit or incorrectly placed if it was ever installed. Again check the FAQ in this section for a write up on this problem.
