92 dakota cranks wont turn
Old Apr 14, 2013 | 09:09 PM
hutaylor93's Avatar
hutaylor93
Default 92 dakota cranks wont turn
My 1992 Dodge Dakota V6 will crank but wont turn over. I have replaced the distributer cap, rotor, and ignition coil and nothing has worked. Looking for any type of help!!!
Old Apr 14, 2013 | 10:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Are you getting spark or fuel? Check for spark on all plugs then check your fuel pressure.
Old Apr 14, 2013 | 10:51 PM
hutaylor93's Avatar
hutaylor93
no spark at all! we checked the coil wire and spark plugs.
Old Apr 15, 2013 | 08:13 AM
DakotaRT1993's Avatar
DakotaRT1993
So you mean it will crank/turn over but won't fire? I'm assuming that's what you meant. Could be the crank sensor. Other than that check the notorious splice and the ASD relay and fuse.
