Driveshaft woes...
I literally just limped my dak home, 4 miles, with a fractured drive shaft. The lobes that the u-joint bearing cups go in...yeah, one side cracked. So my question is....do I get her welded, or do I replace the whole shaft?
Oh,On the upside...I gots a warranty!!! Sadly, I have to wait until monday, if I turn it in.
If you got warranty (how'd you manage that?) have it fixed under warranty. I don't think I'd weld it--and I'm pretty cheap (and have a mig welder.) Downside with welding is that if it breaks again, you'll be stuck by the side of the road, and it could do some damage flopping around.
A driveline shop could probably replace just the yoke.
A rear driveshaft is under $100 on eBay... I think welding ain't worth the stress.
Protip/thread hijack question - if you had to, you could have removed the rear 'shaft and had a front wheel drive Dakota for the trip home, yes?
I know I can't do this on my Rover because it has viscous couplers that would burn up, but my understanding is that the Dak is all mechanical in the t-case.
Heh...I got it on the 20th, from a buy here, pay here joint, and the told them that I wouldnt buy it unless he threw in a 6 month warranty on the drive train. Amazingly, he did it. !8 year old car with a warranty. lmao....
