H.P. and MPG upgrades?
Old May 11, 2013 | 12:49 PM
Cooreman's Avatar
Cooreman
So the only reason my 92 dakota has way more ***** than my 94 is the exhaust?
Old May 11, 2013 | 04:31 PM
BKCowGod's Avatar
BKCowGod
Everything I've read says you can't even tell the difference between the smaller and larger exhaust b/c the torque curve was moved down the RPM range. At this point in their lives, engine and transmission condition have more to do with performance than original manufacturer specs.
Old May 11, 2013 | 09:24 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Yes.
Depending on you "butt dyno" sensitivity you may or may not feel it. The advertised horsepower and torque specs from Chrysler say otherwise.
Old May 11, 2013 | 10:02 PM
Cooreman's Avatar
Cooreman
Well **** man, my 92 has a park band or some thing slipped and doesn't like shifting outta second but damn is she peppy as hell. So I dot think it would do much with the tranny cause mines a little pooched while my 94 is in immaculate condition just kinda gutless I guess we'll not like I feel like it should have
Old May 11, 2013 | 10:11 PM
AZ 360 Dakota
I have a customer with a '94 Dakota like mine and his feels pretty gutless. Granted comparing his '94 with a 5.2 to mine with a 5.9 with the kegger mod, e-fan, '92-'93 exhaust manifolds and y-pipe, and larger throttle body is like comparing apple to oranges but you'd think a V-8 would feel better than his stock '94 does.
Old May 11, 2013 | 10:55 PM
cd36's Avatar
cd36
Considering that 10hp is probably more like 7hp at the wheels I doubt most people would notice it, let alone consider one to smoke the other. Are the two trucks exactly mechanically identical otherwise? 4x4 vs 2wd, rear diff ratio, tire size, engine condition, etc would probably play a bigger roll.
Old May 11, 2013 | 11:02 PM
AZ 360 Dakota
I recently dyno-tuned my turbo-charged '88 Caravan and picked up 22 hp and 38 ft/lbs of torque. I could not tell the difference other than the graph of before and after.
Old May 11, 2013 | 11:10 PM
Cooreman's Avatar
Cooreman
Both 4x 94 has less kilometres on it by about 100 000 diff ratio couldn't tell you and tires were same size
Old May 12, 2013 | 01:30 PM
xtramile09's Avatar
xtramile09
I get 8-10 ha ha
Old May 14, 2013 | 08:11 PM
xtramile09's Avatar
xtramile09
Originally Posted by matteusclement
I did the typical sparkplug wires, cap, rotor, plugs, air filter.
But I also replaced my breather, PVC valve and hoses. Those all helped.
I also took out my Cat, replaced my o2 sensor and thermal sensor.
BUT the thing that gave me the biggest towing boost was my recent replacement of my u-joints and support bearing. Now I have no issues towing.
what and where the hell is a thermal sensor?
