transfer case rear output shaft height?
Old May 8, 2013 | 09:10 PM
inuchan187's Avatar
inuchan187
Default transfer case rear output shaft height?
Anyone have a picture of how high the output shaft should be over the torsion bar crossmember and possibly a picture of the transmission mount? I think my trans mount is bad and letting the rear of the transfer case sit almost an inch lower than stock. I have about a 1/2" of steel under the trans mount and the parking brake cable still has to be tie wrapped to the crossmember to keep it out of the way of the driveshaft. Is there supposed to be something holding the cable between the frame rails? As of now, it just goes straight between the triangle pieces in the corners.
Old May 12, 2013 | 11:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A quick way to test your transmission mount is to see if you can lift up the transmission and separate the rubber and body of the mount.
