92 dakota bucking
Old May 9, 2013 | 04:10 PM
bilzhome's Avatar
bilzhome
Default 92 dakota bucking
My 92 dakota,3.9 is having a few issues...every once in a while while accelatering it bucks a couple time then goes on,never know when its gonna do it,and when it sits while the trans is hard shifinting out of first to second.(automatic)but is fine after that.....it idles perfect,fires right up and runs great...the codes are...12,15 and 55....any ideas
Old May 10, 2013 | 12:31 PM
matteusclement's Avatar
matteusclement
Have you reset your PCM?
By "bucking" you mean that it gives and goes, gives and goes?
Old May 10, 2013 | 01:37 PM
cd36's Avatar
cd36
Here is info on code 15:
http://www.allpar.com/fix/codes/faults/code15.html
Old May 10, 2013 | 09:13 PM
bilzhome's Avatar
bilzhome
Originally Posted by cd36
the bucking was one of the wires going to the coil shorting on the manifold..motor runs perfect..the transmission whines and is hard shifting out of first when cold,but changes fine from second on even to overdrive,after it warm is does alot better...I cleared the codes and drove about 35 miles,stopping a couple places....rechecked the codes and got 12 and 55,no other codes.....
Old May 10, 2013 | 09:47 PM
cd36's Avatar
cd36
Glad you got it fixed. When did you last change your tranny fluid and filter?
Old May 11, 2013 | 02:00 AM
bilzhome's Avatar
bilzhome
just bought the truck from the original owner,the original 3.9 croaked so he put in a motor with 71000 miles,runs perfect,not sure when or if he changed the fluid,gonna do it today and see what happens.the truck has 155000 mile on it.I had a '92 full size with a 318,changed the fluid and the trans died a week later.....
