trans swap
Old May 10, 2013 | 11:35 PM
LA6-250's Avatar
LA6-250
Default trans swap
Has anyone ever seen, heard of, done, or flat out KNOW for a certainty; that a TF8 (727) will bolt up directly to a 1993 3.9L (v6) without any major changes? Also, with a '92 and prior trans they have a sensor on the top. How and where does that have to be ran to?
Old May 10, 2013 | 11:41 PM
shadowthedakota's Avatar
shadowthedakota
the 727 will bolt up to the v6 since the v6 is the v8 with two missing cylinders as long as it is for a small block(not sure if they made them for both). when i get my next dakota i'll be running one behind a 6cyl.
Old May 11, 2013 | 12:04 AM
LA6-250's Avatar
LA6-250
so, other than getting an appropriate driveline. Would it be a simple bolt on, fill up, and drive? Or is there something more to it?
