Strange Trans Issue, Will not engage any gear
Old Jun 26, 2013 | 11:11 AM
jott5555's Avatar
jott5555
Default Strange Trans Issue, Will not engage any gear
I just dropped a 318 and 46rh into my 95 Dakota.. they came from a donor truck, the trans is a rebuilt jasper with under 10k on it. In the donor truck the trans would not engage any gear. No jerk no lurch when you selected a gear it would do nothing. Almost as if the shift selector was not attached.
i pulled the trans apart and everything appeared pristine. No mating, no dirt or metal shavings nothing. I had the Torque converter tested. it came back as working perfectly. so i replaced the pump and installed a TransGo reprogramming kit.
This morning i got everything buttoned up and went to put it in gear and nothing happened, Still the exact same symptom as before. Keep in mind it has a new pump and working TQ converter.. Anyone else have any ideas i can check?
Thanks
Old Jun 26, 2013 | 11:33 AM
jott5555's Avatar
jott5555
Also i checked through the trans troubleshooting FAQ and the only issue i can see that has not been resolved is the parking spur issue. however i do not know how to check that.. and with the torque converter coming back as working.. The only think i can think is to go pick up a new valve body from the junk yard and toss it in hoping it works.
Old Jun 28, 2013 | 02:05 AM
RockGuardedDak's Avatar
RockGuardedDak
Have you tried adjusting the TV cable? Maybe it's so outta wack it's protecting the tranny? Try replacing the shift module on the tranny with a junkyard unit maybe? Just throwing out suggestions as I have no idea what could be causing this. Any check engine codes? Definitely a weird problem, maybe someone with some more knowledge in this aspect will chime in soon
Old Jun 28, 2013 | 07:51 AM
jott5555's Avatar
jott5555
I tried the tv cabke.adjustmenth to no avail. I also did verify I have about 80psi at the cooler. At this point I have no clue.. I had it hauled off to a locak trusted trans shop in hopes they could figure it out. I assume it has to be something with the vb.. really there waa nothing else internally that looked like it had an issue. I will definitely keep everyone updated with reaults when I hear back from the trans shop
