trans question
Old Jul 6, 2013 | 03:48 PM
ednev's Avatar
ednev
Default trans question
My trans is going out and i found one at the junkyard that i know works but my truck was built in 7/92 my title says 93 and the truck at the yard is a true 92. Both trucks have different tranfer cases will i be able to use this transmission in my truck with my tcase.
Old Jul 6, 2013 | 09:00 PM
moe7404's Avatar
moe7404
iam not a trany expert. but i found an external trany filter. sorry its a cut, paste
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
EDIT: must mopar tranys have the coolant line going in at the rear of the main casting.
Old Jul 9, 2013 | 09:55 PM
moe7404's Avatar
moe7404
update on the URLs
Old Jul 18, 2013 | 02:10 PM
rx7_dude2003's Avatar
rx7_dude2003
To answer the original question. Yes
Old Jul 24, 2013 | 04:37 PM
ednev's Avatar
ednev
Lol thank you rx7
Old Jul 24, 2013 | 08:12 PM
rx7_dude2003
I would pay close attention to the flywheel.. And also the out put gear on the transfercases.. Pretty much make sure the seal in the same spots. Some goofy tranys had the seal closer to the edges than most. If the seals are in the same spots ur fine..
This is how most trannys look
