PCM Question
Old Aug 28, 2013 | 12:28 PM
  #21
AZ 360 Dakota's Avatar
AZ 360 Dakota
Originally Posted by robertmee
If I could piggy back upon this thread.
I have a 90 vert I'm preparing to make a 360 swap into. I'll likely have a 94/95 dakota V8 donor truck for parts. I will be using a mopar performance crate 5.9L magnum for the swap (if all goes well...lucked upon one new).
If I understand your information, AZ, the 94 5.2L dakota was a returnless style system and its PCM/injectors will be tailored as such. So, my options are:
1) Swap the 94 gas tank/fuel pump/fuel lines/manifold/injectors/fuel rail into the 90 along with the PCM and call it day...
OR
2) Keep the return style and add the intrepid regulator? The second option I'm a bit unclear on what I'd have to do keeping it return style, and if there are any advantages?
3) Lastly, if I go with a 93 donor truck instead which is return style, would I do the same wholesale swap of manifold/injectors/PCM but keep the fuel system the same, and all is good? My concern is the injector change between 93 and 94. I couldn't find any flow specs on the two styles...Was it purely to accommodate pressure differences or is the lb rating different?
I numbered your questions in your quote so I could answer them accordingly and without confusion.
First off you need to keep the year PCM you use with that year fuel injectors. It's not the fuel pressure rating, it's injector flow rating and the injectors are matched to the computer. Some years are the same but some years are different. To avoid confusion, just keep the same year PCM with the same year injectors.
1) Yes and no. Use everything you listed but you need to use a 94 5.9 computer.
2) Yes. You use the Intrepid regulator to up the fuel pressure to use the 5.2 PCM on the 5.9 engine.
3) Yes.
In short, if you run returnless you have to use a 5.9 PCM with a 5.9 engine. If you return you can run either a 5.2 or 5.9 PCM but if you run a 5.2 PCM you have to use the Intrepid fuel pressure regulator to up the fuel pressure to compensate for the larger displacement of the 5.9 engine.
Old Aug 28, 2013 | 02:37 PM
  #22
robertmee's Avatar
robertmee
Excuse my denseness, but I thought the 94 Dakota 5.2 and the 94 Ram 5.9 had the exact same fuel delivery system...A returnless. I've checked and the Intakes are the same, the fuel injectors are the same, the MAF is the same...If the Air and Fuel in are the same, is it a pressure difference between the 5.2 and 5.9 for the larger 360 heads? Or is the fuel profile different?
If the difference warrants a change, is the ODBI pcm in 94 flashable? Is the EPROM the only difference? Would a chip swap or reburn allow me to use the 5.2 PCM or is it just more economical/feasible to find a 5.9 of the same year? And are 94 and 95's the same then to open up the search for one.
Old Aug 28, 2013 | 03:36 PM
  #23
cd36's Avatar
cd36
I think you need to use a 5.9L PCM because the 5.2L PCM is tuned for the 5.2L, so it will have a different fuel mapping. You can get away with a 5.2L PCM on a 5.9L with a return system because you increase the fuel pressure, which forces more fuel into the cylinder at the same pulse width. On a returnless system you can't mess with the fuel pressure.
Old Aug 28, 2013 | 03:48 PM
  #24
robertmee's Avatar
robertmee
Gotcha...Thanks!
Old Aug 28, 2013 | 08:00 PM
  #25
AZ 360 Dakota
Correct.
Old Aug 29, 2013 | 09:35 AM
  #26
robertmee's Avatar
robertmee
So I secured a running '95 5.2L dakota...Which means, I either:
Wholesale swap everything from intake to fuel tank and find a '95 5.9L PCM
or
Keep return and use the 5.2L PCM and add the intrepid regulator
Assuming I have a 5.9L PCM and that's not a factor, any advantage/disadvantage either way?
NOTE: Not using the 5.2L engine from the donor, but a 5.9L crate
Old Aug 29, 2013 | 11:06 AM
  #27
AZ 360 Dakota
or
I personally like the performance of the 5.2 PCM over the 5.9 PCM on the 5.9 engine. I did back to back runs at the track and got better 1/4 mile times with the 5.2 running higher fuel pressure than I did with the 5.9 PCM running stock fuel pressure. The 5.9 feels like it bogs down down low, I'm guessing it's more for towing where the 5.2 seems like it has more top end.
Old Aug 29, 2013 | 12:30 PM
  #28
robertmee's Avatar
robertmee
Interesting...what gear ratio are you running, AZ?
Old Aug 29, 2013 | 12:51 PM
  #29
AZ 360 Dakota
My rear end is a 3:55 and it's a 2WD 46RH automatic.
Old Aug 29, 2013 | 04:54 PM
  #30
robertmee's Avatar
robertmee
Stock converter also? I'll probably run a higher stall converter and 4:10 gears eventually mated with the 400 HP crate 360. I'm still concerned that the injectors/flow curve combo won't be sufficient since the stock was around 260 HP, so I assume I'll need a tune/flash of the PCM anyway. That's why I was wondering if the 5.2 PCM could just be reflashed.
Do you know if gear changes are handled in the PCM of this era for correct speedo operation?
