94 dakota transmission leak by transfer case
Old Sep 13, 2013 | 07:49 PM
1994dakota's Avatar
1994dakota
Question 94 dakota transmission leak by transfer case
Hey guys, I'm new here. I'm 19 with my first Dakota and I've got a problem and not a lot of cash...... like the title says I have a 94 Dakota slt with a 5.2. Right Where the tranny and the tc bolts together there is a small maybe 1/8 in hole. It leaks atf every time I try to add it. Anything above low on the dip stick leaks out. And if I pull up on a hill Where the front is higher than the rear it leaks. It's not Good I've had the tranny slip on me because of it. Wht is the matter with it???
Old Sep 15, 2013 | 07:10 PM
Brian in Tucson's Avatar
Brian in Tucson
My understanding is that they didn't use a gasket inbetween the transfer case and the back of the trannie. And that if you can remove the bolts and crack them apart, you and clean it up and use automotive RTV silicone to seal them back together. Don't go overboard, use just a thin smear of silicone.
Don't take it as gospel, but that's what I've read somewhere.
Btw, mine's leaking there too.
Old Sep 18, 2013 | 06:08 PM
1994dakota's Avatar
1994dakota
I did it and it worked. U have to fill the drain slot but it stopped leaking. It's not right but it's fixed!
Old Sep 19, 2013 | 10:35 AM
Brian in Tucson
Excellent!
