94 Fuel pump issues
Old Sep 26, 2013 | 02:17 PM
mtbmark's Avatar
mtbmark
Default 94 Fuel pump issues
I put a new fuel pump in and have issues with restart. Old pump had what I'll call a pressure bulb on top of it that the output connected to. New one, same manufacturer and their replacement for original, has connections for supply and return, no pressure bulb.
On start, I need to turn the key on for a few seconds to let the fuel get to the rail.
Otherwise, you get to crank some before the start.
Anyone else have this problem with a replacement pump. Thinking some sort of check valve is missing in the supply.
Another interesting one is the pump seems to search for fuel when the tank gets to 1/3 area. Thought something was wrong with the installation, so I took the tank back out and looked. All fine. Pump sets on the bottom, pick up fine. That made me growl.
Suggestions?
Old Sep 26, 2013 | 03:39 PM
onemore94dak's Avatar
onemore94dak
You should look in the FAQ at the top of the forum. Maybe a picture of the differences in the pumps would help as all the ones I have seen online are the same. Your problem might be the wiring is loose. There is a lot of stuff on this site about these fuel pumps and it seems the only bad mark against these 94 Dak's in reviews is the battery power wire to the fuel pump.
Old Sep 27, 2013 | 02:12 PM
mtbmark's Avatar
mtbmark
Thanks on the troubleshoot. I'll try that and report back for others to review.
Old Sep 28, 2013 | 12:49 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Suggestions?
It sounds like you got a pump for a '92-'93 Dakota. In '92-'93 the fuel system was a return type system. In '94 Chrysler switched to a returnless type system. That bulb on the top that you are referring to is a fuel pressure regulator/fuel filter. If the pump you installed had a port for "return", what did you do with that port? I converted my returnless system to return and have pictures here: https://dodgeforum.com/forum/1st-gen...-360-swap.html describing both. I think you installed the wrong pump.
