squeeking from tranny problem! help!
Old Oct 24, 2013 | 11:33 PM
ian.mckee2693's Avatar
ian.mckee2693
Default squeeking from tranny problem! help!
so my 89 dakota has this noise coming from the tranny i believe....
it only happens when the truck gets going, its sorta like a squeek, and goes away after you slightly press the clutch pedal. it also goes away when u go faster than 30 mph. is it the throwout bearing? or could it just be that the slave cylinder needs a little grease? anyone know or had this happen to them?
Old Oct 25, 2013 | 11:24 AM
Tom A's Avatar
Tom A
Section Moderator
What does it do when you press the clutch pedal all the way down? Do you hear grinding? It sounds like the throwout bearing to me.
Old Oct 25, 2013 | 01:17 PM
ian.mckee2693
Nope no grinding when you push the clutch in. The clutch pedal also feels a little loose.
Old Apr 25, 2014 | 12:18 AM
ian.mckee2693
anyone know???
Old Apr 25, 2014 | 12:21 AM
Tom A's Avatar
Tom A
Section Moderator
Originally Posted by ian.mckee2693
anyone know???
Still sounds like the throwout bearing to me. Has it gotten any worse since you first posted about it?
