ox sensor respond to intake manifold and heads upgrate
Old Dec 5, 2013 | 08:57 AM
Hansuman's Avatar
Hansuman
Default ox sensor respond to intake manifold and heads upgrate
Can anyone tell me if the ox sensor will go crazy if I do a head swap (360 for stock) and pro-flo 2 / M1 or Edelbrock FI intake manifold replacement on my 318 magnum? If so, what can be done about that?
Dodge Dakota 5.2 magnum 1996
Old Dec 5, 2013 | 10:38 AM
Brian in Tucson's Avatar
Brian in Tucson
My understanding is that the 5.9 heads are the same as the 5.2. As for the other stuff, when you disconnect your battery while you're working on the intake stuff, it will reset the PCM and it will relearn the sensor & flow settings. I think it would probably be advisable to replace the O2 sensors at the same time, but other than that the PCM should have no problems.
Old Dec 6, 2013 | 12:19 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
The PCM can make up for some improvements you make. I installed a 5.9 and continued to use the 5.2 PCM. It ran okay and seemed to have a lean misfire at idle. When I looked at the fuel trims I could see that they were pegged lean, the computer was dumping fuel to make up the difference but it wasn't enough. I increased the fuel pressure and the fuel trims leveled out back to close to zero. I doubt installing the M1 manifold will make any difference but a better flowing head or larger valves might. You can read here https://dodgeforum.com/forum/1st-gen...-360-swap.html what I did to fix my lean problem.
Old Dec 6, 2013 | 05:16 AM
Hansuman's Avatar
Hansuman
awesome - thanks guys, then I'll make this happen early next year
