1990 Dakota Fuel pump cap replacement?
Old Dec 20, 2013 | 07:55 PM
colonelhogan44's Avatar
colonelhogan44
Exclamation 1990 Dakota Fuel pump cap replacement?
I'm attempting to find a new cap for the fuel tank of my 1990 Dakota to get it to pass CA smog. I can't for the life of me find one, and my current one is all cracked and pretty close to beyond repair.
See the photos for the piece I'm talking about -- it's the plastic cap that all the hoses connect into. Parts catalogs (rockauto, etc) don't show a replacement and it looks like the design changed in 1990 to a unit that comes with the housing.
Any ideas?
Attached Thumbnails 1990 Dakota Fuel pump cap replacement?-imag0886_zps9d429bd5.jpg
Old Dec 20, 2013 | 08:21 PM
daksnbeers's Avatar
daksnbeers
I believe its one whole piece with the pump. Would have to replace the entire unit. Glad I don't have inspections in florida.
Old Dec 20, 2013 | 09:03 PM
colonelhogan44
1991+ looks like one unit. The 1990 listings show this image:
Old Dec 20, 2013 | 09:20 PM
Reesey's Avatar
Reesey
If they sell the units separate and you cant find a listing for a cap(weird) then your best bet would probably be a boneyard. Someone more qualified than me might know better though.
Old Dec 20, 2013 | 11:19 PM
daksnbeers's Avatar
daksnbeers
Then I would say look in a junk yard or try and see if a part # is stamped on it. Have you checked with a dealer?
Old Dec 21, 2013 | 05:33 PM
onemore94dak's Avatar
onemore94dak
I'm pretty sure you can find it here. I don;t know the details about your rig so I searched close to it. You can insert the details and know better what you want.
http://www.factorychryslerparts.com/...=0&searchTerm=
Old Dec 21, 2013 | 08:39 PM
Tom A's Avatar
Tom A
Section Moderator
If you can seal up the cracks and make it stop leaking, it will pass. If you can't do that, the cheapest option is a junkyard (I'd probably take the whole tank to be sure you don't break something installing or uninstalling the pump module). The best way, of course, is to buy a new fuel pump module and install it. That will also give you the peace of mind that your fuel pump should last for a long time.
Old Dec 21, 2013 | 10:03 PM
shadowthedakota's Avatar
shadowthedakota
when I broke the return line off my pump I superglued it back together. its been working fine every since
