1996 dakota horn not working
Old Dec 23, 2013 | 12:03 PM
Bsmith1621's Avatar
Bsmith1621
Default 1996 dakota horn not working
Ok so a few weeks ago my horn and tach stopped working so checked the relay and it tested bad so I replaced it and still nothing wants to work checked all my fuses under hood and dash and all checked out good so what could be the problem? And if anyone has a pic or diagram layout of the under dash fuse box that would be great
Old Dec 23, 2013 | 11:32 PM
Brian in Tucson's Avatar
Brian in Tucson
The horn relay is on the fuse panel under the dash. Probably yours has lost it's smoke and needs to be replaced. You can get a replacement at O'reilly's, Autozone, etc. for about $7 as I remember. Manny, Moe, & Jacks may even have them.
Old Dec 23, 2013 | 11:36 PM
daksnbeers's Avatar
daksnbeers
The horn/tach fuse is located under the dash #6 15 amp blue fuse.
If you have any other questions about this there is a ton of info in the faq 1 section at the top of the listed threads in this first gen dakota section.
Old Dec 24, 2013 | 02:44 PM
moe7404's Avatar
moe7404
put a ground strap on the steering col.
