93 3.9l kegger mod?
Okay its a little more then the kegger mod but first whats the deal with the EGR do I need it or not I live in Washington get smoged sometimes. if I don't need the EGR can I get a newer manifold without the divider? Will doing the kegger mod removing the divider but leaving the EGR outlet intake mess with the airflow? Next headers if I need the EGR do they make headers with a fitting for the EGR to plug into.
Thanks Pat
Thanks Pat
thats my problem i want to move for a better job but moving 3 hours south of me requires emission testing... unfortunatly with plenum leaking and so on id fail hard so its give up modifying my trucks or better job...
but after plenum repair it should pass, it passed when i registered it so..
(hugs his 91 2wd(gonna be SAS) and 92 4wd
)EGR plays an efffect on emissions and fuel economy as it recirc unburnt fuel so if it was factory equipped it may be required for it to pass.... so as said not advisable to remove.... if it isnt working just leave it till required to repair ..
