doing top end work info needed !
Old Apr 10, 2014 | 08:33 PM
dakotakid17's Avatar
dakotakid17
Default doing top end work info needed !
hey guy im doing my top end now its a 92 318 magnum i will be running a m1 intake with stock heads that are ported but i do want to run harland sharp roller rockers what would be the best ratio to get 1.6 or 1.7 and do i have a pedistal mount rocker or a stud mount rocker im getting a little confused on what i need to get i dont plan on doing a cam at all shes my daily and i have my drag truck already. so this info would be great plz help.
Old Apr 10, 2014 | 08:58 PM
jockjock's Avatar
jockjock
If you are not going to be putting in cams then buy the 1.7 non adjustables.
The exact ones you need are : http://www.summitracing.com/int/part.../?autoview=sku.
Crazy4x4RT has a pretty good install guide on them. There is also a really good install guide for them and your M1 on the snowdigger website. Also for your sake I hope you bought the install kit for your M1, or it is going to be a PITA to source out all the little bits and pieces. The one sold for the M1 is basically sold at cost.
To answer your other question, we have pedestal mounts.
