93 Dakota turn signal/wiper lever
Old Apr 24, 2014 | 07:42 PM
Mikjary's Avatar
Mikjary
Default 93 Dakota turn signal/wiper lever
My turn signal arm bit the dust. It still works, but the end cap fell off. How tough is it to replace the unit? It's a tilt column with intermittent wipers.
I did several searches, but didn't find too much.
Best,
Mike
Old Apr 25, 2014 | 03:29 PM
RobertMc's Avatar
RobertMc
Check the FAq section. There are service manuals there.
https://dodgeforum.com/forum/1st-gen...e-manuals.html
A factory one is listed for the 95, which probably has the same procedure for the switch. (if not 90% the same)
You will need a steering wheel puller to do the job. Some auto parts stores will lend them to you if you don't own one.
