OBD1 Codes? Need Help?
Old May 24, 2014 | 02:12 AM
Master X964's Avatar
Master X964
Default OBD1 Codes? Need Help?
1995 Dodge Dakota 3.9L V6, RWD only.
Video of the codes:
Here are the codes:
33 - A/C Cutout relay circuit
23 - Intake Air Temp. Sensor Voltage High
25 - IAC Motor Driven Circuit
5 - ????
I don't know why it's throwing code #5, there's no code #5, i've done the diagnosis three times and both times it's thrown the same codes
So i was wondering what these codes mean, and what exactly i need to fix?
EDIT: After watching the video for the millionth time, i just realized it might be 35, 32, 55, which would make much more sense, just that first one has a pause after the second number, idk but then it'd actually end in 55.
So with that:
35 - Fan Control Relay Circuit
32 - Fault In EGR Diagnostics
55 - Completion...
ik i have a bad cat, if that has anything to do with the EGR Fault.
Old May 24, 2014 | 07:40 AM
SteveDes's Avatar
SteveDes
Old May 24, 2014 | 07:41 AM
SteveDes's Avatar
SteveDes
Bad cat could throw the 32 code
Old May 24, 2014 | 10:44 AM
Master X964
Yeah, i guess i can see that too, plus you're the second person to say it was 12, 32, 32, 55. Though whats does error code 12 mean? Direct battery input to PCM was disconnect within the last 50 key-on cycles.
Old May 25, 2014 | 09:42 AM
SteveDes's Avatar
SteveDes
12 means the battery was disconnected recently.
Old May 25, 2014 | 02:41 PM
onemore94dak's Avatar
onemore94dak
Here's the code page
https://dodgeforum.com/forum/1st-gen...-96-codes.html
