Distributor getting wet?
Old May 27, 2014 | 12:55 PM
knoxy_14's Avatar
knoxy_14
Yea was gonna grab all new wires cap and rotor and plugs also and see what happens after I do that I gotta find some water....
Old May 30, 2014 | 10:53 PM
knoxy_14's Avatar
knoxy_14
was just wondering could it just be my ignition coil that was getting wet?
Old May 31, 2014 | 10:09 AM
onemore94dak's Avatar
onemore94dak
Could be. I understand your dilemma trying to be accurate. I have found that sometimes the only thing to do is step by step look at and fix each possible problem and any problems you find while checking them as specific diagnosis is not always easy w/o doing something. I second Brian In Tuscan, you should coat eachplug wire connection with dielectric grease to seal it if that works you've fixed it. If not you can change the wires, cap, rotors and coil. I did all that at the same time on mine. If that doesn't work????
Old May 31, 2014 | 04:20 PM
RalphP's Avatar
RalphP
Knoxy_14 - that's always a possibility. I was doing some "Justin Case" stuff last tuneup (I mean, 260K+ miles on the ORIGINAL coil??) and found my coil was cracked - which was probably one of my intermittent misfires (probably because, along with new wires to replace the ones melted when the injector quit firing due to the ECM failing, and the new plugs due to the old ones being sooted up, it's hard to say ...).
BIG note - whereas there's nothing wrong with shopping, don't cheap out. That is, find a good quality one and price shop on that brand and model, instead of just buying the cheapest one you can find.
Also, grab a new condensor (the cylinder mounted at the coil). THAT could even be failing with age.
RwP
Old May 31, 2014 | 06:13 PM
knoxy_14's Avatar
knoxy_14
yea i replaced the cap rotor wires and plugs just not the coil when i bought it im going to try that and wait till i can find somethign to see if its gonna shut off
Old Jun 1, 2014 | 10:09 AM
onemore94dak
Soak it real good with a hose while its cold and parked at your house. Then see if that prevents a start.
