trans cooler line questions..
Here is the story. my lovely 42rh trans went out and while in the process of removing it for the rebuild i busted both transmission lines near the transmission.
I am going to replace the entire line (Transmission to cooler)with new steel line but here is where my question comes into play.....
What size should i use. Ive read that going to 1/2" oil resistant hose is better and reduces back pressure and overall helps cool better.
Should i upgrade to the 1/2 steel line? Or stick with the stock 3/8".
My aux cooler has 3/8 barbs but i can easily adapt down to 3/8s trans hose for hooking it up.
