Truck is leaning to passenger side
Old Aug 15, 2014 | 01:31 AM
Willy_B's Avatar
Willy_B
Default Truck is leaning to passenger side
I noticed this a couple weeks ago, but forgot about it. I saw it again today while walking up to my truck from the rear. My front passenger side is leaning a good 1.5 inches ( I did not look at the rear suspension yet ). It is very noticeable when walking up to the truck from the rear. Some say the shocks need to be replaced, but can bad shocks lower the front passenger 1.5 inches?
Old Aug 15, 2014 | 07:01 AM
RalphP's Avatar
RalphP
No, but a slipped torsion rod (or a broken one!) can.
RwP
Old Aug 16, 2014 | 04:46 PM
Cooreman's Avatar
Cooreman
Check your leaf springs for cracks and what not and what was said earlier torsion bar.
Old Aug 19, 2014 | 11:12 PM
Willy_B's Avatar
Willy_B
Thank you both for the info.
The torsion bolt on the passenger side slipped. It was 5/8" lower than the drivers. When I got the bolts to identical lengths, the passenger side measurement from ground to fender was still 5/8" lower than the drivers. Is that normal? I decided to turn the bolt more to make the measurements even.
Old Aug 21, 2014 | 09:28 PM
Tom A's Avatar
Tom A
Section Moderator
Ideally, you would have somebody measure the height on both sides with you sitting in the truck, but it's probably close enough that it doesn't matter.
Old Aug 24, 2014 | 05:43 PM
92DakotaClub's Avatar
92DakotaClub
i know im a few days behind but..
Its not uncommon for one side to be weaker/worn out more then other, this is often seen even when vehicle was new aswell
