95 Dodge Dakota Rollover Valve hep urgent
Old Aug 20, 2014 | 01:42 PM
esin8785's Avatar
esin8785
Unhappy 95 Dodge Dakota Rollover Valve hep urgent
I have a 95 dodge dakota 3.9 v6 and well the fuel pump went out and when trying to take off the house to the rollover valve that sits on top of the fuel pump broke and I didn't think much of it cause I thought the new fuel pump would come with one, well I found out they don't and finding the part well it's back ordered and idk if they will ever make it again, What I was trying to find out though is can I use another rollover valve from a 90 to 98 possibly on this truck or any truck that has the same fuel tank underneath
Old Aug 20, 2014 | 06:36 PM
Brian in Tucson's Avatar
Brian in Tucson
Have you tried a wrecking yard?
Been covered: https://dodgeforum.com/forum/2888465-post1.html
Old Aug 20, 2014 | 07:22 PM
esin8785's Avatar
esin8785
I did try but they told me they didn't have anything so I just said f it and found it finally online and ordered it earlier, Ill post if I have other issues with this truck, this truck has given me so many problems wth was dodge thinking when they made these years vehicles, stupid door hinge is welded to door frame which it broke on both doors cause the doors are simply to heavy but you have to take of the front fender to get to the bolts that attach it to the vehicle and replace not just the hinge but the whole freaking door
Old Aug 22, 2014 | 11:47 AM
esin8785's Avatar
esin8785
Well just got a email saying they do not have the part, is there any vehicle i can take this part off other then just this model truck i need something different, they have 93, 96 dodge dakota in the junk yard will these models work for the rollover valve
Old Aug 22, 2014 | 12:20 PM
Brian in Tucson
Did you even follow the link I posted? O'Reilly and others carry the Dorman valve in stock. The Dorman part number is 911-001.
O'Reilly even has a really nice picture online.
Old Aug 23, 2014 | 11:25 AM
esin8785's Avatar
esin8785
so this valve this doorman valve will work as long as I get a different hose to splice into the other vacuum hose, If so they have the part here at the local autozone for not much at all, I need to be sure this will fit our 95 dodge dakota before I go out spending more money on something I really don't know, The link you posted the user has a 96 dakota which they run a different fuel pump, I believe the only ones that run the same fuel pump as our year is 94, I also dont have the other valve that was originally was on that part was destroyed trying to remove the sucker from the pump and thrown out, Can I just use this valve without having to do no mods to the valve itself or what is it I need to do exactly
Old Aug 23, 2014 | 01:37 PM
esin8785's Avatar
esin8785
alright I am going to just go buy this and hopefully can rig it up the way I need it to be, I'm hoping that it will just go in there and that's it, if I got to buy some o rings or what ever Ill do that but for right now I need this truck going and it's been sitting here for over 2 months like this and I need a vehicle, If this don't work then f the valve and ill run it without it
Old Aug 23, 2014 | 02:33 PM
esin8785's Avatar
esin8785
I got the rollover valve and all I had to do was remove the metal ring and o ring off it and it fit snugly thank you so so much for all your helps
Old Aug 23, 2014 | 08:07 PM
esin8785's Avatar
esin8785
Alright guys I have finally finished this up and well it didn't start up right away but an hour later after dumping a tiny bit a fuel in the intake it started up and has kept on starting up with no HICK, I can't believe it worked, also for anyone going this route you must remove both the metal clip and the orange O Ring that comes on part 911-001 and it will go in there without a hitch fits snugly on the fuel pump, When you mount the tank back into position there is no way for that valve to accidentally pop out cause it sits against the bottom of the bed, Thank you all so so much for the help dearly the help that I needed, now for the thermastat and blower motor for the heater and ac
Old Aug 25, 2014 | 11:24 AM
Brian in Tucson
Glad to know it worked. Congrats.
Sometimes you just have to take a chance.
