caused motor to run better by accident
So I've been making this thing run better for 13 months now. I'm at a point I need to get the tranny rebuilt I'm waiting til I can get my other rig running.
Anyway I'm screwing around under the hood, lubing the belt wheels and taping up the frayed tape making sure all is tight then the next time I drive its almost as if it had been tuned up.[EDIT I should say the improvement is that it responds more quickly to peddle input than it used to as the valve issue obviously means it isn't running great.] I had taped the wiring harness from by the EGR through the passenger side firewall corner up to the computer.
I'm figuring that I made the wires connect better but IDK if its a short or a prob with the computer?????
Does the harness go bad in this area?
It's also revealed a bad valve tick that is sucking away power and gas when I accelerate on hills and at 55>mph. I may be wrong there I'm a fix it when it goes bad mechanic not fully knowledgeable on all ways motors behave.
Should I wait for the tranny rebuild to be done of try to solve the problem first? No codes.
I decided to remove the harness connection to the PCM. Sand fell out of the back of it. I cleaned the connections and WD'd it. I tightened it back up and now the rig runs even better. I suppose part of my problem may have been this connection. I will update once I have the tranny rebuilt.
WD40 is not what you should use there for longevity.
Buy a tube of dielectric grease ("bulb grease" or tuneup grease) and put that into the connector. Otherwise the contacts will oxidize a LOT sooner.
RwP
RwP
Since I did this and did a motor flush & change of the oil I put in after the timing chain and intake plenum, I now have a pronounced tappet or lifter noise most of the time. It occasionally goes away. ????? Any ideas????
