Emergency brake issue
Old Jan 23, 2015 | 11:44 PM
evintho's Avatar
evintho
Cool Emergency brake issue
My '95 Dakota, when I step on the E-brake sometimes it holds. Most of the time it doesn't! Doesn't even click as it goes down. Just pops right back up! I'm thinking it's a worn ratcheting mechanism. Confirmation or opinions before I go to the yard and pull another one? Thanks everyone!
Old Jan 24, 2015 | 09:43 AM
tbugden's Avatar
tbugden
You should be able to look under the dash and observe the ratcheting mechanism as you push it and whatever the problem is may be very obvious. Or may not.
Old Jan 24, 2015 | 10:40 AM
92DakotaClub's Avatar
92DakotaClub
might be a stuck release handle... seen that were it dosent pop back, had to push handle back in manually(spring related) or might be rust, or somthing of the sort
Old Feb 3, 2015 | 12:47 AM
evintho's Avatar
evintho
Update:
Pulled it out and found a worn ratcheting mechanism. Picked one up in great condition out of a '93 at Pick-N-Pull - $23 out the door. Slapped it in, works like a charm. All is good!
