reindexed keys --> rock solid ride
Hey just curious if there's a few ideas of things to look for. I cranked the reindexed keys up to somewhat level the front with an add-a-leaf rear. The front is about 1" lower than the rear. I think it was 23.25" from the centre of the wheel to the top of the wheel arch.
The bump stops were shot, so I didn't really worry too much about them when I cranked it up, but the ride is absolutely rock solid now. I do have a bit of clearance to the remainder of the bump stops, so I'm not sure if it's the shocks that are maxxed out, or if the torsion bars just have so much tension on them that they allow no movement. In theory, I should still have SOME clearance to the upper control arm, before it hits. It's not unbearable to drive, (actually rides great on a smooth road) but every crack or pebble on the road is bone jarring, and speed bumps almost make the nose bounce, even when crawling over them. So I was just wondering if there was any ideas of what I should look for when I check it out this weekend. If I have to drop it back down, I'll grudgingly do so, but it's still not exactly even with the rear so I'd really rather not haha. |
Can you see if the shocks are maxed out? Honestly, if it didn't do it before and now it dies, your only choice may be to back off on it some and see what happens.
The shocks do seem to be pulled out quite a bit at a glance. Was just wondering if it's a possibility or common occurrence. Part of me was considering unbolting one side of the shock and taking it for a short drive to see if the rigidity changed. But figured I'd post up in here first to see if there was any other ideas.
Thanks! |
yea when cranking the stock shocks have little to no up travel, i had to find some a little longer for mine, no luck, made a relocation bracket for the top, also on up travel it easily hits the bump stop....
remember putting more preload on the torsion with tighten the suspension up, regardless how you did it, more lift = tighter suspension = rougher ride, my dakota before the modded key and crank i was like driving a cadillac, after all said and done, was like driving in a jeep, rough as hell but i had mud boggers which are stiff tires aswell running almost no air lol |
Yeah i expected it to firm up a bit, and was actually looking forward to it. While the stock flex is nice off road, I'm constantly getting hung up on things. And the handling was actually too floppy for my tastes on road. Firming it up a bit was a trade off that i was happy to make. But it really went from soft and floppy, to no suspension at all.
With confirmation that the shocks could be the issue, I'll see what i can figure out. Troubleshooting in winter is no fun, but modification or repair with a goal in mind is something i can grit my teeth and get through haha |
