for longer trans life i found this EXTERNAL filter. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side, this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. ONLY use high pressure hose. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
onemore94dak
close
- Join DateSep 2013
Liked:153 Times in 145 Posts
You can use this page to contact Dodge for a build sheet. It takes a few days. Use the link in the email you get back for future questions.
http://www.dodge.com/webselfservice/...ull&category=U
