3.9L V6
Old Oct 28, 2005 | 11:30 PM
92dodge's Avatar
92dodge
Default 3.9L V6
I have a 92 dakota 2wd with a 3.9 L V6 multi-port fuel injection. Has anyone ever put a 1990 3.9L V6 throttle body engine in a 92? If so does the muti-port system bolt on to the 1990 block? Are there any other changes required?
Thanks for any replies.
Old Oct 30, 2005 | 07:26 PM
92dakotasport's Avatar
92dakotasport
Default RE: 3.9L V6
That i would like to know i also have a 92 Dakota with a 3.9 im rebuilding <parting out a 91>
Old Nov 28, 2005 | 04:26 AM
undertaker420's Avatar
undertaker420
Default RE: 3.9L V6
I'm currently in the process of switching a carburated 3.9 with a TBI 3.9. There were a number of things that I had to look at and switch. You would want to check your full pressures, a TBI requires about 14 psi, I"m not sure what a MPI would require. I also know that the MPI has hydrulic lifters and runs off a surpintine belt and your TBI has numerous belts. I imagine you would probably have to change wiriing as well since you will have more injectors on your truck. I'm pretty sure that the blocks would be the same. I know for a fact that they don't change from 87 to 91 but I"m not sure about anything after that.
Old Nov 29, 2005 | 01:32 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: 3.9L V6
The 92 multi port injected motors run on 35 psi from the factory, but you can run more. I dont think the 92 system works on the because the pre 92 motors are hydraulic roller motors and the heds are different.
