91 5.2L smog pump
Old Jun 12, 2015 | 01:23 AM
scottyspades's Avatar
scottyspades
Default 91 5.2L smog pump
I want to remove the smog pump from my motor. It sounds like hell and I want it gone. Can I yank a tensioner pulley from a 92-95 with a 318 and use a belt from that model year? Or do I have to use a different length belt. I noticed while roaming the boneyard that the newer first gen Dakotas with 318s have no smog pump so I'm wonderin if I can do this simple and easy
Old Jun 12, 2015 | 06:21 PM
onemore94dak's Avatar
onemore94dak
I found this http://www.dippy.org/forum2/index.php?topic=11858.0 Apparently you need an 83.5" belt once it is removed.
