94 Dakota idle problems
Old Jul 25, 2015 | 04:35 PM
jesse1562's Avatar
jesse1562
Default 94 Dakota idle problems
I just wanted to share some knowledge with other owners. My 94 1rst gen. 3.9L was idling slow and rough after a tune-up (plugs, wires, cap, rotor and air filter). Local mechs. couldn't scan obd1 on Saturday so I was forced to trial and error my rough running and stalling Dakota. After trying throttle position sensor that I returned, I bought an idle air control valve. Problem solved ! Runs like it should at 255,000 miles. Good luck with yours
Old Oct 26, 2015 | 03:42 PM
Corey Taylor's Avatar
Corey Taylor
I recently replaced my plenum and all major gaskets on my Dakota a 94 3.9 2WD just like yours and I have had a bad surging problem and rough idle... I have a Haynes repair manual and I cannot find a idle air control valve.. I was going to try replacing that and was wondering if it may be called something else... Like an Idle Speed Control Actuator? Thanks in advance.
Old Oct 26, 2015 | 03:46 PM
MathewRood's Avatar
MathewRood
Have you gone over all the rubber vacuum fittings making sure they're not leaking? Just starting at the simple things
Old Oct 26, 2015 | 03:52 PM
onemore94dak's Avatar
onemore94dak
Corey the IAC is the sensor that goes into the back of the throttle body. You can clean it with the right cleaner and a brush. be gentle. For anyone who wants to you can get a Snap On MT2500 on ebay for about $300 that will do a lot including resetting your IAC.
