Brake issues.
I have a 1994 Dodge Dakota. I noticed recently that the parking brake light on the dashboard stays on. Also the brake pedal has more travel than it used to. I started investigating and found that if I press down the parking brake pedal, it doesn"t seem to release. Also, I took off the front tire and noticed that turning the rotor is difficult. I could turn it but it took some effort.
Any advice on how to proceed?
I checked the brake fluid and it is full. I removed both back wheels. On the driver side rear drum, I am unable to remove the drum. I am thinking that either the parking brake is not releasing or I need to loosen the self adjuster to back off the brake pads. Problem is that I'm not sure how to loose up the self adjuster (star).
Is the direction I need to turn the self adjuster is start with the screwdriver handle high and then bring down.? In one direction the self adjustor is easy to move, but in the other direction it won't turn.
Also, on the rear wheels, if I have both wheels off the ground and tires removed, should I be able to turn the drum freely?
thx
thx
Sorry, this reply is probably too late.
I bet that your parking brake cable is seized.
But if you want to try backing off the star adjuster, you can do it with two screwdrivers. With one you gotta hold up the springloaded adjuster lever and the other you spin the star wheel Kinda difficult to get into the right position but easy once you get the hang of it.
