Help Locating Wiper Transmission
Old Sep 14, 2015 | 06:30 PM
KevinSandidge's Avatar
KevinSandidge
Default Help Locating Wiper Transmission
Hey fellas; so i'm about to tackle replacing the wiper linkage bushings and had the thought to go ahead and replace the entire transmission but i'm having trouble locating one. The ones i do find don't go back to 1991, that's what i need to find...windshield wiper transmission assembly for a 91 dakota 2wd 3.9l. Where do you guys go to buy this? thanks
Old Sep 14, 2015 | 07:03 PM
kahanabob's Avatar
kahanabob
don't think you will find one other than a junk yard. does yours not work? the old sane 'if it's not broke don't fix it". pay very close attention to the orientation of the linkage arms. very easy to get them in backwards and/or upside down.
Old Oct 2, 2015 | 01:49 PM
KevinSandidge
that figures and i'll take care on the 'putting em back in the same way' thanks!
Old Oct 2, 2015 | 03:06 PM
RalphP's Avatar
RalphP
Also, while rebuilding, be sure to put some lithium grease in each of the bushings.
That helps extend the life QUITE a bit.
RwP
Old Oct 2, 2015 | 08:38 PM
Ndr's Avatar
Ndr
I lucked out and found one on Ebay for my '95. Is yours stripped out? if the splines on the parts that the arms attache to are in good condition, I would just buy some new bushings, disasemble the transmission and put the new bushing in (and add the grease as mentioned above.
I did this with the one I found on Ebay before installing it since the bushing on it were pretty nasty looking. Works smoothly and is nice and quiet.
Old Jan 22, 2016 | 11:18 AM
KevinSandidge
thanks for the good advice y'all; it's a real hassle reaching in those tiny access openings. i've got more serious issues to deal with now
Old Jan 22, 2016 | 11:32 AM
RalphP's Avatar
RalphP
Umm ... after removing the plastic cover under the cowl piece, I had no problem getting in and removing the transmission so I could work on it on my table.
RwP
