Upper control arm mount
Old Dec 24, 2015 | 01:22 PM
marcar1993's Avatar
marcar1993
My truck needs bushings too. I understand the fear that wrenching on those bolts could damage the mount ears. While yes they are the alignment spot, no one touches these as they are for caster/camber, and a normal alignment is a toe-and-go. Here's my plan, and what I've done sucessfully on other trucks. Get a can of spray paint, any bright color, now clean up and paint around the bolts, this will give you a perfect starting point for alignment, put it back together in the same place it came from, in the shadow of the old bolt. Then, if you cannot easily break the bolts free, cut them. Use a grinder, sawzall, torch, or whatever you need to, just BE CAREFUL of everything around them. Then just go get new high grade bolts, grade 8 sae or 10.9 metric or higher with locking nuts and reassemble. Done. Do it yourself, if you need to farm out anything, just bring the control arms to a shop to press in and out the bushings.
Also, if your balljoints are welded in, get new control arms from a junk yard or something and put in new balljoints the right way.
Old Dec 25, 2015 | 01:34 PM
RalphP's Avatar
RalphP
The only problem with generic bolts is that the current one are T_headed so that they will not twist when you tighten the caster/camber adjustments.
And if most of the alignment shops where you live are only toe-n-go, they suck. You CAN whack this design out of alignment with a big enough pothole at a high enough speed ...
The bolt is discontinued, but it's also been used on almost ALL Mopar products from the mid 60's up.
RwP
