pillar gauge pod
Old Dec 21, 2015 | 04:33 PM
Ajh0791's Avatar
Ajh0791
Default pillar gauge pod
so i am trying to install pillar gauge pod with a few gauges. what is the easiest way to do that? i was thinking of removing the foam molding of the dash board, but not quite sure.
i have a vacuum gauge and oil pressure, from a past car that runs no more.
thanks in advanced!
Old Dec 21, 2015 | 05:04 PM
Why mess with the dash if it mounts on the pillar?
Old Dec 21, 2015 | 05:13 PM
Ajh0791's Avatar
Ajh0791
cause i need to get inside to run wires and hook them up. constant, switched, ground, headlamp switched and vacuum. i know where they all go, but i just want to hid the wires and do a better job than my last car.
Old Dec 22, 2015 | 12:03 AM
RalphP's Avatar
RalphP
Why not just remove the current pillar, and use the same run that the wires up to the overhead use?
Even if you put that piece back on, and the gauge pod over it, that's how I'd do it, instead of tearing more of it up.
RwP
Old Dec 22, 2015 | 08:29 AM
Ajh0791's Avatar
Ajh0791
That was my next thought. Thanks for the suggestion. Ill try to post a pick when I finish it!
