No first gear - 3.9 Auto
Just started having an issue with the truck. I'd type out all of my troubleshooting procedures but there might be a character limit on the forums :P
The rundown: 1994 Dakota 3.9. Auto transmission. Engine runs strong. First gear seems to have disappeared completely. If I put it into first, it goes nowhere - just revs. When in drive, I'm very slow to get off the line until I get up around 15-20 mph. I assume that's because I'm actually "starting" in 2nd.
When I'm moving, it's good. No problems on the highway at all. Upper gears seem fine. When I'm near a mountain, it's bad. Real bad. Figure I should tap the real experts for wisdom before every shop tells me it needs a new tranny
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Yep, no problems with reverse at all. The only other thing I noticed and omitted from my initial post was that if I start the engine and immediately drop it down to first gear, the amps will measure really low almost to the point that I expect the engine to stall. During normal driving conditions, everything is good.
Guess I'll park it until I get a chance to get under there and check it out. I have extremely limited experience working with any transmission so it'll be a learning experience ;]
So after doing a ton of research on the 42RH/E it seems like the most likely culprit is going to be the governor pressure solenoid. I also often read about an accompanying sensor that should be replaced at the same time. I can't seem to find this part on rockauto or anywhere else for this year (it shows up in 96+ models of the dakota). Was this pressure sensor a later addition to the transmission or am I just not able to find this part anymore?
