WHITE SMOKE on CAT beak in.????
I don't know if my results are normal for new CAT and pipes from mani back.
The procedure to break in the CAT is; start it without hitting the gas. Let idle 5 minutes, then take it up to 2500 for two minutes and shut it off. Let it cool. Then take it on a ride to see how it runs.
I hooked up the MT 2500 and started it. It ran fine no codes. Then I took it up to 2500 and I was holding the throttle with left hand and MT with right so I didn't see it until the two minutes was almost up but it was making a lot of white smoke.
Is that normal for a new system?
I'm gonna take it on a ride I'll check in when I get back.
Otay man my arrrrr key is on the fritz and I don't always proof read.
